RVcircus
Feb 23, 2016Explorer II
Anmacc2 wrote:msgtord wrote:
You did allot of extra work for nothing. I replaced mine and did not have to remove the cord. The replacement cover is "notched" so you can push through the plug without disconnecting from the converter.
Mine is also notched so all I needed to do was push the cord through. Something else I do... I don't pull my power cord out. I run an extension cord right up to the hatch and keep the plug protected. I have to replace the extension cord every year to 18 months because of sun/salt/elements fatiguing the cord. It is much easier to replace the extension cord rather than replacing the cord to the converter.
Mine is notched as well, but the end of my cord is too big to push through. Maybe my plug is unusually large? Maybe I just need to get stronger? The hatch I picked up isn't the greatest and it seemed to be on the verge of breaking if I forced it.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
