- cwitExplorerWhen I did my 5er I left the luan down and added 1/4 " right over it. This gave me a nice walk on roof. Mine was done because the staples were pulling out that held the plywood down. The second layer was glued and screwed.
- westendExplorerAFAIK, there is no exterior graded Luan sheet goods. It all has an interior compliant glue. As was stated, use an exterior grade 3/8" Plywood. It should be stamped "BCX" or similar. The first two letters are the grade of finish plies and the last denotes exterior grade. A surface filler is typically used on screw indentations and seams, that keeps the EPDM from resting into a crease or hole.
- Shop that did mine used 1/4 inch exterior plywood.
They then coated each joint with leveling compound.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
