- mikestockExplorerIf you don't remove or bypass the tank the pyramid will eventually be a problem. With the volume of water per flush it may take a little longer to form than with a n rv toilet. If you can just imagine: If you were the t...d, what would you do?
- AlmotExplorer III
John&Joey wrote:
A common toilet uses 1.6 gallons, a black tank holds let say 40 gallons. That gives you about 25 flushes before you need to dump. 25 flushes for two people would be every day or two for dumping.
Now if you left the valve open you would get the pyramid of poo in no time at all.
Proven solution to prevent this:
With one person, keep the shutter-valve on the drain pipe closed and only open it every other day (and then close it again for 2-3 days).
With 2 people open it once a day - say, in the morning.
Needless to remind to always add some water or liquid waste before using it again after emptying.
RV toilet with all-porcelain bowl with a proper swirl-flushing like Dometic 310/320 would be my preferred solution when water supply is limited. - TheKunkelsExplorerI've been reading up on composting toilets.
Doesn't sound like any trouble at all. Will be great during winter when the parks water is off. - John_JoeyExplorer
Bill.Satellite wrote:
...You could leave the black tank open if you like as the volume of water would prevent and sort of a poop pyramid from forming. ...
I wouldn't bet the farm on that. A couple of 45's to the black tank then a side exit out and you would be singing the dried up pile song in no time.
Then again, that would be someone else's problem to fix. :R - Bill_SatelliteExplorer IIIf this is going to be a "cabin style" that never moves then the answer is yes, you can install a home style toilet. You could leave the black tank open if you like as the volume of water would prevent and sort of a poop pyramid from forming. You could also close the holding tank valve and use dump ever few days. That only takes a few minutes so it's not a big deal at all. You mentioned just getting a riser or a taller RV toilet which is fine as well but if you like a residential toilet...Go for it!
I installed a MircroFlush toilet by Microphor which looks and functions like a residential toilet without the standing water in the tank and I would never go back to an RV toilet. - John_JoeyExplorer
coolmom42 wrote:
ScottG wrote:
You would have to bypass the holding tank to use a regular toilet. Otherwise, the solids will collect in the black tank and clog it.
HUH?
It's a math thing. A common toilet uses 1.6 gallons, a black tank holds let say 40 gallons. That gives you about 25 flushes before you need to dump. 25 flushes for two people would be every day or two for dumping.
Only real option is to take the tank out and hard pipe the house toilet to the park sewer line. - coolmom42Explorer II
HUH? - Dick_BExplorerWe installed a Thetford Residence toilet that is a little higher than standard.
- StraboExplorerI just replaced ours with a taller, porcelain toilet. Works great.
- romoreExplorer II?? That is what the black tank does. Why not use a riser or purchase a taller rv toilet?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
