John_Joey
Jan 16, 2017Explorer
coolmom42 wrote:ScottG wrote:
You would have to bypass the holding tank to use a regular toilet. Otherwise, the solids will collect in the black tank and clog it.
HUH?
It's a math thing. A common toilet uses 1.6 gallons, a black tank holds let say 40 gallons. That gives you about 25 flushes before you need to dump. 25 flushes for two people would be every day or two for dumping.
Now if you left the valve open you would get the pyramid of poo in no time at all.
Only real option is to take the tank out and hard pipe the house toilet to the park sewer line.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
