The dinette area has a table, but to create bed space, that table has to be lifted out of the two metal cylinders that support it. It is then placed to form the bottom side of the bed between the two...
If you have no other bed option, you could build a lighter table but be careful it is sufficiently robust to handle the weight. One inch plywood is where I’d start. With bracing, maybe 3/4 inch.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
