WeBeFulltimers
Jul 20, 2014Explorer
We are fulltimers in a 38' Montana 5th wheel and I discovered that we were air conditioning our basement storage area because of the furnace return grills on 2 of our steps up to bath/bedroom area. Now each spring after we are finished with the furnace for the season, I pull the grill covers and place a piece of luan plywood behind each one. Now all the cool air stays where it should be and the a/c's each run less. I stained the luan to match and you can't tell they're back there. Just be sure to remove them when furnace is needed again in the winter.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
