Prairieboy315's avatar
Sep 24, 2019
RV toilet with a self contained holding tank
Hi, I am restoring a 1978 14' TT that my grandfather once owned. It has the original toilet that needs replacement. This toilet is bolted to the floor, and vented to the outside. It is plumbed in and has its own self-contained holding tank (about 5-6 gallons) situated directly below the toilet bowl. The toilet is directly attached to the sewer drop pipe and waste valve. Apparently to empty, one simply attached the sewer hose and opened the waste valve and the toilet emptied itself. There is NO black water holding tank or room for one.
I want to replace this toilet with a similar type but can't seem to find such an item today. (I see lots of portable toilets where you remove the waste container and dump it down a septic or toilet, but none that will allow you to use a waste valve to avoid handling the waste.
Does anyone know where I could locate such a toilet?
Thanks for any information you may be able to provide. BTW, I live in Canada so a Canadian supplier would be best if possible?
  • You could start fresh.
    Install a new holding tank with the new style toilet adapter plate.
    That way you can use any RV toilet you want and the tank would have the drain valve you want.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: Jun 07, 2026
