- Chevyman2006ExplorerThose of y'all that have this...
Does it look like the opening mechanism can be removed WITHOUT damaging it and installing in existing door panel or a piece of plexi? - az99ExplorerI made one out of clear .090 lexan with a custom machined polished aluminum knob. Works good but I still am not crazy about the look of the clear panel next to the white panel. I was thinking of sand blasting and painting it flat white.
Update- I removed the other white non moveable panel and replaced it with a clear piece of Lexan also. Looks better now. - updownarchExplorerI have been looking for a replacement screen door opener exactly like that one. Can you tell me where you saw/purchased that one?? Thanks
- oh_boyExplorerI took my handle off. Hate the damn thing. I put one of those old style screen door rollers where the handle was, Left the handle catch in place. The roller rolls over and rests behind the catch. I have a CW/Wally push bar on the screen door, Just a push or pull to open. If we go out I slide the grab handle across the door in case the dog gets too pushy.
They were at Lowes/HD for about 2.00 in the cabinet knob section. They have a small nylon roller and metal base with spring and 2 screw holes.. last about 3 years and then a new one. - Bucky_BadgerExplorer
Judo x-ray wrote:
So who makes this and where can you purchase it?updownarch
Read the whole thread, it's here - dancewithGodExplorerWho makes these clear door slides with handles and where can I find them?
- BarneySExplorer III
Posted in the middle of P.2 of this thread. Here is a source where they can be purchased.
Barney - Harvey51Explorer
wittmeba wrote:
I got tired of having to open the little hatch to access the screen door so I tried this.
Looks good! - dancewithGodExplorerTHANK YOU, Barney!
- Harvey51ExplorerOh, I saw this one in an RV store for about $5 and chickened out on making one. It works well.
So well I figured I would never need to open that slider again and siliconed it shut! Dumb. Of course I need to slide it open in order to open the main door when it is closed. I used a utility knife to cut the silicone, being careful not to cut it off - now it is much more bug proof than before.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 13, 2025
