RoyB
Apr 18, 2016Explorer III
You also have to be concerned with the THIN RV walls. They are 1/4-board and screws will just pull through them...
You need to hit a stub or best bet is to install a back-board of 3/4 board across the wall where you want your shelf.. If your back board doesnt tie into any studs then perhaps you can use what they call MOLLY BOLTS in the four corners. These spread out behind the wall and give great support strength...
Then you can just use regular screws to mount your shelf into the back-board...
Something along this line of thinking like this HDTV is mounted...
Roy Ken
Roy Ken
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
