Has any one replaced their plastic kitchen sink with a steel one? I have the one with a sink and a smaller one just to the right and it is basically useless. The wife would like to have one larger one...
Its not difficult to do. Just make sure you have enough space, both above and below the counter. Some RVs have faucet(s) that mount on the counter, not on the sink as most household sinks are designed to do. Make sure the sink you get will cover the faucet holes if this is the case. You will also probably have to rebuild the drain. Your local hardware store will have the necessary plumbing supplies.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
