cs2kplus's avatar
cs2kplus
Spring Over Axle Conversion
Greetings again.
I have posted about flipping axles. Which I have learned it is know as "spring axle conversion".
I have an old 89 trailer. Fleetwood Taurus. It is low and I have issues getting in and out of my driveway.
I asked an RV repair place what it would cost. One said $400 to remove axle (unclear if that one or 2 - 2 is what I have). Then the cost of replacement parts.
Another said $1000 for the job.
I am not sure what a good price range should be?
I think I agree that the actual change in height will be 4". That works for me.
I have some questions:
Its interesting how this axle (3") slings down. Will this be an issue - as opposed to a centered axle?
Here is a shot that I suspect the perch is not actually welded? Does not look like pics I've seen online.
Here is another view of the stackup
Any thoughts on all of this info?
Thanks,
Wayne
  • cs2kplus wrote:
    redoing the whole axle would mean basically everything..correct? Drums, brakes, etc. basically you'd keep the tires....and by then you can get bigger ones?
    Yes. You can buy a complete assembly from different axle suppliers. A dealer will gouge you pretty good. It may be worth your while to do an internet search for RV axles.
    Another thing to consider is if you tires are older than 5 years then you should replace them anyway. I hope they don't look as bad as the axle. Ha.
    Assuming you would need a 3500# axle and springs, here's a place to shop.
    https://www.etrailer.com/Trailer-Axles/Dexter/35545E-ST-EZ-89.html
    https://www.etrailer.com/Trailer-Suspension/Universal-Group/SP-212275.html
    You would need some new U bolts and bolts for the springs as well as maybe a set of leaf spring shackles.
  • @GoDucks: Thanks for the great advice and info.
    I got a quote from a trailer (not dealer) for 1900 for everything including tires. Yeah it's high. But I think its pretty good for everything. This would be an upgrade as well to a straight axle with 6 lug (currently 5) wheels. It's an old camper..but we love it. To axles are like the engine of a trailer and I feel I can justify the cost.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,351 PostsLatest Activity: Jan 18, 2025
