DrewE
Sep 06, 2015Explorer III
If you have access and clearance in back of the outlets (if they're in a cabinet, say), you might be able to retrofit a box and a standard household outlet. A good (e.g. spec-grade) household outlet is likely going to be higher quality than RV outlets, and the screw terminations are IMHO superior to the insulation piercing ones that RV outlets generally use. Best are the screw clamp ones with a sort of plate under the screw, IMHO.
If you decide to do this, check that you have sufficient slack in the 120V wires.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
