Hornnumb2
Sep 08, 2015Explorer
You can use a shallow drywall box and new receptacle, no problem. The only problem I have ran into is the drywall tabs that you tighten are not made for that thin paneling. you can add some scrap behind the panel or notch the box so they will pull up tighter.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
