unbob's avatar
unbob
Thin-Lite LED light fixture?
Anyone here upgraded to LED lighting with a Thin-Lite LED light fixture?
Found what appears to be the complete Thin-Lite LED product line here.
I'm planning to order the Model #LED626P Indoor LED light and would be interested to hear of any customer experiences.
Yes, I know there are cheaper ways of upgrading but I want to purchase an entirely new fixture - not a conversion using my existing fixture. But if anyone knows of a cheaper source of this specific product, I'd like to know.
Thanks, Rob
  • Bottom line, the Thin-Lite LED626P has lower amp draw and produces more light than my existing model 626 fluorescent.
    Partial Thin-Lite product description:
    This is Thin-Lite's LED version of the popular fluorescent model 626 and P2626 lights.
    Amp draw of 0.40 to 1.25 amps (4.32 to 14.4 watts), lumen output of 720 to 2400 lumens.
    Note: the standard fluorescent model 626 draws 2.2 amps and outputs 1650 lumens.
    Thus, I get 45% more light (on high setting) with little more than half the energy consumption. Sounds good to me!
    Plus, the LEDs basically last forever. F15T8-CW long-life lamps (36,000 hrs) are now available on Amazon for about $13 so maybe I can't justify the switch to LED on cost alone. No matter, my primary goal is lower energy consumption and equal or greater light output.
  • Hi unbob,
    http://www.premierltg.com/should-you-replace-your-t8-fluorescent-lamps-with-t8-led-tubes/
    "As we can see, T8 LEDs have a leg up in regards to lifespan, yet the fluorescent’s higher lumens per watts ratio equates to better light output Not to mention, they are a fraction of the price of LEDs. Even with their greater lifespan, you’d be hard-pressed to see any ROI on the T8 LED before it needs replacing – no matter how you crunch the numbers it just doesn’t work. Thus it seems, from a financial standpoint, changing to these LEDs simply doesn’t make sense at the current price point."
    Please try to "play nice".
  • Hi,
    I'm also a full timer now--and yes as my tubes fail I'll move to led. However, so far none have failed. (drat? lol)
  • The life of the LED is great compared to the 18" Florescent, we replaced 8-9 bulbs a year until 3 years ago. We went with LED, no problems since. But we are fulltimers so the 50% of the lights are on most of day.
  • Hi unbob,
    Yes, because that is what this thread is about. Replacement of the thin light system saves almost no energy per lumen.
  • pianotuna wrote:
    Hi,
    Unless the existing lights are toast, there is no reason to change to led technology. Almost no energy savings are to be had.
    I assume you're referring only to replacement of fluorescent lighting - not incandescent.
    I observed a huge decrease in energy consumption when I converted all my incandescent lights to LED a few years ago!
  • Hi,
    I'll change mine out as they fail--but that will be ages yet.
    There is one other reason to change--and that is low temperature use. The oem units don't like cold too well at all.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,393 PostsLatest Activity: Oct 02, 2025
