We want to add some shelving (wire rack) in our lav. How do you identify where the struts/ wall frame members run vertical? In a house 16" OC is the rule. This would be in a new Winnebago Trend23L
You can use a stud finder. Inside wall joints are joined together usually on a stud. You can also tell by tapping on the walls, and can hear a difference when you hit a stud.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,410 PostsLatest Activity: Jan 18, 2025
