path1's avatar
path1
Water regulator question. 35 or 45 or max PSI?
What do you consider the max your water regulator should be set at?
My old non adjustable water regulator says "max 45" but really only get 33. My shower head works fine and everything seems to be OK. But if I could get a little more pressure the better. Of course I don't want to over do it.
Picked up a Watts yesterday that adjusts and I can set the pressure where I want it.
Wondering what do you run yours at if you have adjustable type?
Thanks
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,395 PostsLatest Activity: Nov 08, 2025
