Ron3rd
Mar 27, 2013Explorer III
dan-nickie wrote:
I believe you will need to remove the regulator from the Q100 to use the low pressure connection.
Correct, as your trailer will supply regulated (low pressure) gas from the port. The Weber is designed to handle high pressure straight from a tank or bottle, thus, it has a regulator too.
The idea is you only want one regulator in the chain or the pressure drop will be too great.
This question comes up so often and there are some excellent posts with parts list on what you have to do and what fittings you have to buy that I wish they would make the topic a "sticky". I'm getting ready to convert my Weber Q over as my new trailer has the quick connect port too, so I'll post the links when I find them.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
