boubou64
May 12, 2013Explorer
Ron3rd wrote:Jim & Betty wrote:
Hello
I am running two regulators with no problems on a Weber BBQ. From what I understand the propane regulator on the RV runs at 11 inches and some of the BBQ regulators run at 5 or 6 can not rember exact number. So if the main is higher than the BBQ there should be no problem.
JimR
Hi Jim,
I've heard the same thing. I'm going to try it your way and see how it works.
Which part and how did you connect to the Weber leaving the regulator?
you saw no difference?
I am in the process of converting it to use the propane on the RV - lines are all there going to the back of the coach for the RVQ
I see most people remove the regulator but would prefer not messing with it if a good alternative was available.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
