Fairway9
May 14, 2013Explorer
I run my Weber right off the high pressure side using an extended stay kit. Only problem I've had is there is a check valve (confirmed by Weber) that will close if you turn the RVQ on to quickly, in which case you have to wait for the pressure to drop off. Great BBQ.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
