dockmasterdave
Aug 01, 2020Explorer
Update
I looked online and found a 60 amp surface mount circuit breaker for $33. I can get 2 36" 6GA battery cables with eye ends.
1 will go from the battery terminal to the circuit breaker.
The other will go out of my battery box to connect to the existing 6GA wire. The existing 30 amp fuse block can stay in place to run my other loads.
They currently have the 10GA to 6 GA connection under the TT with a huge wire nut. I will put an eye on the existing cable and connect to the new cable with a bolt, then waterproof the whole connection.
This sounds like the RIGHT and safe thing to do. Much better than the factory setup. Thank you for pointing me in the right direction.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
