handsome51
Oct 03, 2016Explorer
Everybody seems to be working themselves to death every time they set up, on where to check for level. Just do it once. Buy you two HOOKUP MEMORIES(brand name) They measure in degrees. All the other ones I have seen measure in inches.They read a little past 5 degrees. Here is one website: http://www.campingabsolutely.com/store/hookup-memory-levels-motorhome-camping.html
Level your RV one time with a level on the refrigrator freezer plate.When you have the refrigrator level. At the front of the RV put one level on the front and one on the side. Then when you stop somewheres you can see if you are level enough to keep the refrigrator on. When you get to your RV site, you can see right off what you have to do to get your RV level. After a few time , when you see how much your RV is off side to side. You will know from experience how much to put under the wheel on one side to make the RV level side to side.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,420 PostsLatest Activity: Sep 23, 2026
