Mako_Kupo's avatar
Mako_Kupo
Wiring 12v clearance lights to AA Pack
hey guys, so I'm rebuilding my '79 Class C from the ground up. its being rebuilt to the point it is a flatbed truck in my driveway at the moment, with each wall being built separately and then laid up at the end, a few days from now. after that comes the wiring, which will be a clean install.
anyway, ill be vlogging/videoing the entire trip I'm taking, leaving in the spring. I will be using a lot of cameras at night time, so I wanted my clearance lights to be toggleable with a switch, separate from e everything else so I could turn them on for night time shots, giving reference to where the rv is.
I want to do this without killing my battery, so I discovered these 12v battery packs.
https://www.amazon.com/gp/product/B00VE7HBMS/ref=crt_ewc_title_gw_2?ie=UTF8&psc=1&smid=A353AQG9I0DZD6
then I found individual led lights, just enough of them too
https://www.amazon.com/gp/product/B00EE43ASW/ref=crt_ewc_title_gw_3?ie=UTF8&psc=1&smid=ABTCCZRAZEZHS
these look like they will continue wire on, from one bulb to the next and continuing the string
https://www.amazon.com/gp/product/B001N7PX6K/ref=crt_ewc_title_gw_4?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
what ill do is run the lights into the oblong led clearance light boxes, and wire them to the AA pack and turn them off/on at night as needed. is there anything else I need for this? thank you so much!
  • I would consider led's and making sure they do not appear to be clearance lights. Vehicle inspection rules can be a pain, so make it obvious they are auxillary lights. No yellow or red lenses should avoid any hassels.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,408 PostsLatest Activity: May 09, 2026
