MrWizard
Jan 09, 2018Moderator
the best thing to do
is just run a new circuit from the inverter to behind the fridge and mount a new outlet, that is what i did
other wise put the whole house on the inverter
trying to 'break out' the fridge circuit from the power center breakers and re-wire to the inverter, will still require wire from the inverter to the that circuit and a junction box to connect the circuits together
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
