pianotuna
Jan 09, 2018Nomad III
Find out which breaker is for that outlet. Find out which breakers are on the inverter already. Move the wire from the existing breaker to one of the circuits powered by the inverter.
Or
Add a 15 amp transfer switch where the default wiring is powered by the inverter. Then when plugged into shore power the fridge will be powered bypassing the inverter.
I choose to power the entire rv (other than the converter) from the inverter.
Or
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
