Sam_Spade
Jun 10, 2019Explorer
RobWNY wrote:
My old tires were rated for 65 PSI. My new ones are 80 PSI. I was told I'm just fine with what I did.
Let's try this one more time.
What the tires are RATED AT makes no difference.
What pressure are you ACTUALLY USING in them ??
If your load has not increased, you should NOT be upping the pressure just because the new tires could handle that if they needed to with extra weight.
YOU SHOULD NOT HAVE INCREASED THE PRESSURE JUST BECAUSE YOU PUT ON DIFFERENT TIRES. DID YOU DO THAT ??
About Fifth Wheel Group
