William_Willard
Jul 14, 2020Explorer
The walls & floor are probably made of 2x2`s -- In the factory, the walls are made on a table & one side is glued & stapled -- The other side is left open so when installed, it`s secured with screws & then the paneling in stapled to that side -- Find the side that was not glued & remove the paneling -- Unscrew the wall & remove it-- Don`t worry about the ceiling falling or sagging -- It won`t -- The floor may be OK after it dries -- It`s probably 5/8th OSB & 2x2`s -- Homedepot will have anything you need -- Remember, You gotta tear hell out of it before you can fix it -- Have fun -- Bill Willard
About Fifth Wheel Group
