porknbeanr
Jan 30, 2013Explorer
Hello Joe,
Take a look at the Rieco Titan Ground Control system. It replaces the front landing gear with two independant jacks and also has rear independant lifting jacks to complete the job. Each jack is controlled individually with a wireless remote so you will not tweek your frame. (First level front to back and then side to side.) Each jack is capable of lifting 5K# and can lift your rig off the ground. (tire change). You mentioned you are mechanically inclined, I had mine installed but after seeing it done I should have done it myself. Got it online for under $2200 delivered to my door. Absolutely love em. PM me if you have any questions.
www.riecotitan.com/groundcontrol
About Fifth Wheel Group
