joe_blow
Mar 09, 2014Explorer
Wizbangdoodle wrote:joe blow wrote:
You will be happy you did so. Good luck and remember there are two ways to operate them (high torque/low speed....low torque/high speed) The first handles my trailer the best....if it sounds confusing just read the instructions it will sense.
Thanks Joe. I've heard people say use the high speed to get them to the ground and then switch to the high torque to lift. Makes sense.
Not sure what they are talking about my friend but tha tis NOT possible if I am not mistaken. The motor roll pin is knocked out of the shaft and the gearbox/motor assembly is permanently moved to obtain either torque or speed....you cannot switch between both without doing what I explained above......unless we are talking about the same thing :)
About Fifth Wheel Group
