JIMNLIN
Jan 14, 2015Explorer III
jsrore wrote:
wanted to thank everyone for there opinions and GREAT info.
Being new to the 5th wheel area just want to make sure i TRULY understand pin weights, GAWR, GVW, etc, etc, etc
look forward to trading in the MH later this year and getting a new 5th wheel.
Thanks
Jeff
Good luck on your search.
In your OP you say your pin weight may be in the 3600-3900 lb range.
Doing some math shows the 2500 Ram has a 6200 RAWR. These trucks rear axles can be around a 3000 lb which leaves the 2500 truck with a 3200 lb payload.
The 3500 SRW would be a better choice for a 3600-3900 lb pin weight if the right package is chosen.
Look through the Rams Body Builders Guide spec sheets for the SRW ram that can handle that much load.
About Fifth Wheel Group
