BTPO1 wrote:
BB_TX wrote:
Not all manufacturers breakers are interchangeable. Get the manufacturer model number off the breaker and then google it. I had the same problem finding a 20/15 breaker. Googled the model number and found numerous sources. Bought one on line, delivered in a couple days, and installed it.
And no, do not leave the water heater on a 30 amp breaker. The wire is not likely sized for that current. A short could cause a fire.
X2, it is a 30-15 breaker for a reason. JMO
Reason........
Breaker slot size.
30/15A breaker takes up same space as a regular circuit breaker.
Can be replaced with single 30A and single 15A. They just have to be same style and narrow so the 2 fit in space slot/space as the doubled breaker
No other reason as they are 2 separate breakers that function independent pf each other
