hoodidean's avatar
hoodidean
5rv with the highest R factors
I'm looking for the manufacturer that has the highest R factors for insulation. We full-time in Missouri and currently are in a Montana. The Heartland Big Country is about the highest I'm finding. Anyone have any research on this?
  • one of the "tricks" some manufactures use to build large R-factor numbers is to treat reflective values as if they are R-values .... example: an aluminum space blanket has higher reflective values but very little R-value .... the best way is to see if the line of camper being considered has been certified by an independent source (Dometic for one) which test campers and provides high and low temp ratings .... from Dometic getting such certification is free to manufactures .... if a company won't tell you the rating or won't submit their campers for testing, that says more than any claimed R-values .... in addition they play games with the ratings given .... example side wall values don't take windows into consideration .... with regular RV window glass having an R-value of 1 and Thermopane having an R-value of 2, campers with large windows can't possibly have high numbers for the entire surface of a side wall .... many have little or no insulation is slide floors and/or walls .... knowing the construction and having the unit tested to see how it performs is far more important than any single set of numbers
    Jim
  • DRV just the insulation R factors NOT values of the assembly. Those would be higher.
    Floors R29
    Walls R16
    Roof R25
  • The Heartland Bighorn below:
    R11 sidewalks
    R34 roof
    R38 floor
    The Landmark
    R11 sidewalks
    R38 roof
    R40 floor
    The information was taken taken from Heartland brochures.
  • I think the DRV Mobile Suites have the highest ratings. Their sidewalls are 3 1/4 inch thick compared to the usual 2 inch sidewalls.
