Coach-man
Jan 11, 2015Explorer
The bed of your truck is sheet metal! To give it strenght it is bent, corregated, the installation of my bed rails has tabs that go between the folds of the bed so wheb you tighten down on the bolts the sheet metal will not colapse. How do you install those tabs without cutting the liner? If not installed, the sheet metal will colapse, or not tightened enough?? You are hauling a lot of weight behind you, you really want to "get it right"!
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
