zb39's avatar
zb39
5th wheel hitch
Do they make one that will pop out or unbolt so I can still use the bed of truck.
  • Halmfamily wrote:
    B&W is the only way to go in my opinion.
    "Opinions" are like elbows (or?) - everyone usually has one or two.
    Simply stated there *are* differing opinions...:S
    I haven't had the others - - but MINE is best!..:S..:S
    OP - lots of excellent options -
    do *YOUR* research, decide which one is best for *YOU*....:C
  • Most all 5er hitches can be easily removed from the truck. Some leave the mounting rails in the bed (which are very low profile and have minimal impact on using the bed) while some use an underbed mounting system that does not leave visible rails in the bed. I have had both. The underbed mounts leave a cleaner looking bed. But the ones that do leave the rails in the bed did not prevent me from using the bed for whatever I wanted to haul from lumber to an ATV.
  • Yes, but they do tend to be more expensive than some that do not come out easily.
    B&W Turnover Ball and Companion 5th wheel hitch as suggested is one excellent hitch.
  • All 5er hitches "pop out" so to speak. I'm not following the question
    OP are you looking for a hitch that doesn't use standard hitch rails that stay in the bed. Even with hitch rails you can still use the bed. Its more of a cosmetic thing.
  • yes...go to Etrailer.com plenty of videos and info, put your truck info in and follow the information.
