Nomad
Jan 17, 2020Explorer
5th wheel tires
What are considered the best tire for 5th wheels today
Have a Cedar Creek weighing 11,700 wet and it is time for a change
twodownzero wrote:Do you also check your car or truck and remove any Chinese made parts? And remove all the Chinese made parts from your computer? TV? Microwave? Many of those parts have the capacity to cause a lot of damage to your house if they self-destruct. The only way to judge some things is by their past performance. Sailun's past performance is exemplary, arguably better than Goodyear, not a Chinese company.mileshuff wrote:
True but I believe Sailun tires are designed by an American based engineering firm, manufactured in China to be sold in markets outside of China only. Vastly different than the numerous China bomb mass market companies.
The problem with anything from China is quality control. If you get four good ones, great. If you get three good ones and one that is trash, and it blows up, it's going to take out the side of your trailer and do far more damage than just buying good tires in the first place.
I won't use Chinese tires no matter what their reputation or brand on the side. It's just not worth it.
CALandLIN wrote:cummins2014 wrote:Cummins12V98 wrote:
"So according to YOU, and that inflation chart, I should be inflating those G rated tires at about 70 psi."
YEP, Add 5 psi to the chart.
No I am not the only person doing so.
My Avion had GY "E" tires inflated to 80psi. Changed toy to GY "G" because there were no acceptable US Made "E" tires at that time so I went to the GY "G" tires and the chart said 80 so i ran them at 85psi. Ran this for several years and thousands of miles with perfect tread wear and NEVER hot.
Charts are there for a reason.
It just seems you are the only one promoting it, but if you say so.
Read any replacement tire SOP and they all follow the industry standard that says; the replacement tires MUST, provide a load capacity equal to or greater than, what the OE tires provided at vehicle manufacturer recommended cold inflation pressures.
joebedford wrote:
I was surprised to see in this thread that Bridgestone has discontinued the R250. I have 6 of those on my TH. They've aged out. Thinking of replacing them with Sailun S637. What's the best place to by them? I'm in Florida.
joebedford wrote:Cummins12V98 wrote:Yes I run E tires but they're LT tires not ST tires. A lot more robust IMHO.joebedford wrote:
I assume you run "E" tires? If so this is a stellar option.
ENDURANCE ST255/85R16 @4080# at 80psi weighing 51#.
