N-Trouble
May 12, 2015Explorer
jlud wrote:
I would rather tow a TT th and be well under weight ratings than go over the ratings for a 5th wheel. My 9,000 lbs dry TT has a 4k capacity and tows just fine with a sway bar set up. I would not be scared from buying one by saying it won't handle well because it flat out isn't true...mine handles just fine for a newbie at towing...no white knuckle moments or inadequate power or worrying about safety of being overweight.
A 5th wheel might pull better, but I can tell you mine goes perfectly fine as a tt and zero complaints.
Have you ever towed a 5er?
Your TT is a different beast than a bumper Toyhauler. Guarantee you your hitch weight is much less than 1400lb. Toyhaulers put a lot of weight on the hitch assuming your going to be loading the back with a couple thousand pounds of toys.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
