jstaffon
Oct 08, 2018Explorer
5th Wheel Winterize and De-Winterize process
I've winterized my 5th wheel multiple times and have it down to a smooth process. I'm trying to find the correct procedure to de-winterize. The part that is confusing is the isolation of the hot water tank. The winterizing process has you drain the hot water tank and then isolate it with 3 valves so you bypass the tank when replacing the water with antifreeze. It's unclear to me if you're suppose to put all the valves back to normal (including the bypass for the hot water tank) prior to de-winterizing and running fresh water through the lines. It seems like you will run some antifreeze through the hot water tank if you do that making it harder to run enough water through the system to flush all of the antifreeze out. If you leave the hot water tank isolated when you de-winterize while running fresh water through your lines you keep the hot water tank free of antifreeze and streamline the process. Am I making sense or am I worried about a non-problem? Thanks in advance!
