rtaylor0830ExplorerMar 06, 20166pt hydraulic leveling systemCan you use the leveling system to raise tires off found for service ( bearing repacking etc).
chrizgExplorerSep 08, 2016I was told that if you lift all 4 tires off the ground the axles would flip. Is that true ?
Related Contenthydraulic fluid reservoir for leveling systemAir Hwh leveling systemDamaged hydraulic leveler hosesFave hydraulic leveling system?Re-level 5er with lippert hydraulics
