- hdfatboynjExplorer@ mdamerell
I did for the price. A used 350 SD would still run me around 25K or better. I will have the E450 SD modified and ready to tow for just over 5K. If I get 3-5 years out of it without any major problems,I'll be way ahead of the game. But only time will tell - mdamerellExplorerWe have a friend that converted an old ambulance into a vehicle to tow his 5er. Sounds similar.
Slide out cover
Some people swear by them others chose to just sweep them off before closing. There are pro's and con's. - hdfatboynjExplorer@ Gregg, What are slide stoppers? Tried looking it up and can't find anything. @ Stickdog, Yes a dually. @ Edbehnke, No sir it is a E 450, It's a cut away. It has a van front but the 450 super duty frame, suspension & has 4 rear tires. My neighbor works for a company that makes rescue vehicles. This one was a used ambulance. It has 110K miles on it and a GVWR of 19,000 lbs.
Thank you for all the tips. - mdamerellExplorerFirst off congratulations.
Only word of advice is to do a 2nd walk around when you think you are ready to go checking lights and visually check the jaw is shut on the hitch. A "tug test" is also a good practice. Just hold the brake controller slide to set the trailer brakes and give the trailer a little tug with the truck to make sure everything is properly connected.
Empty parking lot makes a great place to practice backing.
Be safe and have fun. - edbehnkeExplorer III think you have a F250, not a E250. anyway, get rid of the dually if you have a dually, you don't need it.
2 batteries and learn how long before you have to dump...that's about it, enjoy. - stickdogExplorer"Ford E450 Super Duty Duely "
Isn't that a "Ford F450 Super Duty Dually" or just "F450 SD DRW"
Congrats on the new 5er. - Greg_The_HammerExplorerInstall slide toppers on every slide.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
