Old-Biscuit
Oct 11, 2015Explorer III
joeburnes wrote:Old-Biscuit wrote:
Only 1 A/C (even 15K) you are going pretty dang good.
Got any roof vents........stuff a accent pillow in them to block the sunlight
Our rear window had a large day/night shade that took 2 to raise/lower plus recliners were in the way.
Replaced it with 4 black out curtain panels.......closed they dropped temp in recliner area significantly.
Extend awning as much as possible....helps shade side of rv
Clean return air filter routinely
Keep the EVAP Coil CLEAN
The EVAP coil? What is it, where is it and how do I clean it? lmao
When you remove return air filter look up inside unit,,,,,,that is the EVAP coil ......you have to remove roof shroud and then sealed cover over EVAP to gain access for cleaning it.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
