Coach-man
Mar 19, 2016Explorer
Your primary concern is the clearance between the top of the bed and the bottom of the 5th wheel. That can be fixed by adjusting your hitch, and or pin box. Then as stated, with air ride you can adjust the rear TV height. If that does not level the trailer, consider larger tires/wheels if you have clearance. The final as stated would be a sub frame assembly. If the dealer is not helpful contact the manufacturer, and ask them how to fix the problem. If still no solution, look at purchasing another 5th wheel from a different dealer.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
