Durb
Mar 31, 2016Explorer
It looks like you are in good shape but here is some food for thought. My trailer came with a non adjustable pin box and TorFlex axles with no adjustments and I was nose high. I ended up with a trailer saver TS3 as it is 14" instead of the Patriot's 16" (Hensley can configure it to 13" if you wish). I have to admit I am only 5 1/2" rail to trailer but I only travel paved roads and have had had no problems yet. Should I need more clearance I can air up the hitch to give me an extra 2+ inches of on a temporary basis. If your funds are unlimited you can have the TS3 with on board air and adjust the ride height from the cab. I have air from my PacBrake so adjusting rail clearance is not an issue. This is an expensive solution but one side benefit is a real nice ride.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
