RTBabich
Mar 01, 2015Explorer
mikakuja wrote:I built our second set of rails without welding. The only welding would be the tabs that connect the rails to the track brackets. I used tabs that were a bit thicker and wider than the welded on tabs held together with three 1/4" flat head bolts & nylon lock nuts. The previous owner must have left something on the upper bed when raising it one time because the tabs and track brackets on one end were bent slightly. The welds were "torn" (not sure what the correct word would be) halfway.
As said above, if you already have the Happijac system it is more than likely built ready to add the second rail set. Any rv dealer can order the rails, ..... If you are handy and have a welder and some angle it's not hard to copy the design from the existing bed...
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
