valhalla360
Jul 29, 2022Navigator
spoon059 wrote:
In your scenario you have to guess how many blocks you need, try and hope you are right. If you're right, perfect. If you aren't, you pull forward and adjust and try again.
With the Andersons, you climb up the angle until its perfect and you're done.
At best its the same amount of time, at worst, it isn't.
And you have to hope the anderson doesn't slide and you have to pull forward and reset or go find the rubber mat.
I usually get it right the first time with boards...so again, it's pretty much a wash.
About Fifth Wheel Group
