fj12ryder
Jul 29, 2022Explorer III
schlep1967 wrote:Nope, if you need three inches of lift, 6 blocks is plenty. That's about 2.5 inches, with is fine. It's not rocket science.
When comparing to the lego blocks the Andersons are much quicker and easier. For a three inch lift for a double axle trailer you will need to lay out at least a dozen lego blocks. For the Anderson you stick one under each tire and drive on. Done. Using boards can be just as quick but then you have to store several 6-8 foot boards.
Either way works, just whatever you're happier with.
About Fifth Wheel Group
