Old-Biscuit
Oct 23, 2016Explorer III
skidooman93 wrote:Searching_Ut wrote:
Would need more specifics about your trailer to know for sure, but with the Andersen ultimate you will probably end up being able to turn slightly less sharply with your trailer than you would be able to turn with a conventional hitch. Most of the newer medium sized trailer now use a variation of the lippert 1602 pin box. It has a long arm, and will sometimes hit the bed rails of your truck when you have the hitch set low which you tend to have to do with the new ram trucks to get your 5er anywhere close to level. The Andersen pin adapter will either lengthen or shorten the effective length of your kinpin by 4 inches. More than likely you will have to shorten the length by putting the pin in front of the ball to keep from hitting the bedrails in tight turns.
The Andersen hitch moves the ball 4 inches behind the axle on a ram shortbed, which gives you the ability to turn slightly tighter, However, the shortened pin arm resulting from putting the pin 4 inches in front of the ball removes that advantage. I just switched from and Andersen ultimate to a B&W hitch a few weeks ago and returned today from a 2500 mile trip of a couple weeks, lots of different driving conditions. With my Andersen, I could get approximately 75 to 80 degree during optimal flat smooth turns. With the B&W which I have set back 4 inches same as I had the Andersen, I find I can get approximately the same 88 degrees, if not slightly more that Heatland advertises for their nose cap.
Bottom line, without knowing which pin box you have, and how high you can get away with adjusting your hitch, I can't tell for sure how you would have to install your Andersen Pin adapter which effects turning radius a fair bit.
Thanks for the info. I believe the pin box is a 1721 or something like that. The goosebox option fits the 1602 and the 17XX I have.
So I expect the same adjustments you had, my truck may sit a little lower with it loaded it is a 2500.
Why did you go away from the Anderson?
Because of DAMAGE.
His post was the one I LINKED in my first post.
Which wasn't bashing just providing information about an incident with use of Andersen
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
