DirtyOil
Aug 15, 2016Explorer
bucky wrote:
Dirty, Rams don't have aluminum beds.
bucky, I understand that, point was no deflection or dents, even when I had to "grind" out the spray bed liner to get the Curt fifth wheel adapter plate to sit low enough to allow me to slide the turnover ball pin into place it didn't even rub/scrap the paint I sprayed on the box where I had removed the bed liner. The so-called experts (non-Anderson users) would have us believe that the Anderson would dent or cause deflection (was just outside) and used a straight edge, box floor is as suspected flat and level no deflection! So, whether you have an aluminum or the excuse auto makers call a steel bed...the Anderson will not dent, deflect or even rub the paint off the box floor!
All this is coming from those that don't use the hitch...its something rather new and some have a hard time getting their heads around the new idea...the World is round not flat!
I'll post some pictures... when I get around to it.
About Fifth Wheel Group
