N-Trouble
Oct 08, 2015Explorer
This has come up previously. I tried it the last time I hooked up my 5er and it made no difference after putting the pin weight on the hitch. That is why I ask. If you have a rubber matt I could see the need to re-torque, but IMO its not needed otherwise. My pin weight is 2Klb dry so maybe some heavier pin weights may see a benefit.
And this needs to be removed form 4-6: "You are now ready to attach your 5th wheel trailer to the base unit". Trailer already gets attached in 4-4...
About Fifth Wheel Group
19,043 PostsLatest Activity: Aug 23, 2026
