Me_Again
Oct 08, 2015Explorer III
The real question is the pickup bed constructed to handle thousands of lbs of weight in consencrated points in the bed without deforming it? I believe the answer from the truck manufacturers would say no. Stating the bed is just sheet metal that was not designed for such service. If you dent it, then that is the users fault not theirs.
There have been many misconceptions posted here including that the gooseneck hitch holds up the weight, when it is used to pull the hitch frame down on the sheet metal bed floor. Chris
About Fifth Wheel Group
19,043 PostsLatest Activity: Aug 23, 2026
