cummins2014
Oct 09, 2015Explorer
Learjet wrote:
I'm liking my bed rails more and more...since I don't care or need a flat bed when the hitch is removed. I used the Curt custom brackes with a heavy plate bolted to the frame on each side with 3 large bolts. Then the plates meet under the bed rails and support the rails with the spacers so the bed doesn't crush. Very robust design.
underneath the bed rail pictures. If you look closely you can see the top spacers
I had the conventional bedrail setup on my previous truck, great setup, other then not a complete empty bed. Although I never found the bedrail's to be much of a hinderance .
I think overall this puck system is great, but as far as I know if you go a slider ,you are pretty much stuck with a picture frame. I'd like to see Andersen come out with a puck design on their fifth hitch .It would be a great setup. It would sure quiet down the opinion givers on the bed deflection. I have never been too thrilled with the picture frame ,just another 75 lbs of weight, and then you have to pile a bunch more iron on top of it.
About Fifth Wheel Group
