PawPaw_n_Gram wrote:
Garrik wrote:
Does anyone use the one cup keurig in there rv? I wonder how many watts it pulls.
From the Keurig web site:
K10 Mini - Power: 1,425 Watts
K75 Platinum & K45 Elite - Power: 1,500 Watts
The B130 you see in a lot of motels runs lowest - Power: 700 Watts
Keurig doesn't list amps but several folks have posted tests - the run 10-12 amps for about 10 minutes.
A coffer maker is often the second or first most powerful draw in an RV.
A Mr. Coffee type coffee maker draws 850-1050 watts and around 7.5 amps depending upon how quickly it is designed to brew.
Even the old reliable Faberware 8 Cup Percolator is a 1,000 watt device.
I was surprised, I looked at our house Cuisinart, only to see that it is at 1075 watts (IIIRC). I never thought it pulled more than the Keurig. With that being said, two RV trailers, never a problem
Cale
